Speedfan damage - need help!
karatekid
Hey I need help with my computer I installed speedfan and played around with it a little and now my computer won't boot up. Obviously I'm on another comp right but I don't know what to do. It seems like I'm not supposed to change fan settings, its as if the computer can only turn on on certain settings. Anyway I don't know where this post should be its originally an hp computer but I've made a lot of changes, recently I changed the cpu fan cause it was noisy. When I power it nothing comes on the screen but the computer seems to turn on. Ok thanks.
Speedfan has the ability to alter clock timings.
Can you gain access to the BIOS screens via the delete key? If so, go in and reset to default.
if that does not work, get out the motherboard manual and read how to reset CMOS.
I don't know why but it is working right now. I just turned it on and it worked, I definitely wasn't expecting that to happen. Hopefully there aren't anymore problems. Thanks for the quick suggestion, although I saw it just about the time when my computer turned back on.
