When a Quad-Core CPU is rated at 2.4GHz (Q6600 for example), does that mean each core uses 2.4GHz with a total of 9.6GHz or is it more like 0.6MHz for each core?
Also if you have a Quad-Core, is it necessary to use a 64bit OS or will everything run just fine with 32bit?
