Speed diffrence between SATA and IDE
militaryman1010
Is the cost worth the upgrade to SATA and should i go with one 10,000 rpm drive or 2 regular drives running in raid 5 and 10 i think.....thanks
7200 drives in SATA are slightly faster then the same drive in PATA, everything else being equal. The 10K Raptor is very noticably faster, as in WOW, that's fast.
I use the Raptor 74 for my program files and the 7200 drives for general storage. It seems to make a nice balance. I tried a pair of Raptors in RAID, although slightly faster there was little or no WOW factor for the dollars spent.
Luck
You won't notice much of a difference switching to SATA from IDE in the same drive. But upgrading to 10,000 rpm makes a big difference. Also, you get to be futureproof.
Futureproof how? By not being to install many applications on a 74gig drive?
One of us is very confused. :confused:
You need at least 3 drives to run RAID5, and 4 to run RAID10
I think you mean RAID1 or RAID0? Those are the ones you can do with 2 drives.
RAID1 is always a good idea, if a little slower on the writing. Full redundancy.
RAID0 is pretty much always a bad idea unless you backup daily or more often. RAID0 is just begging to lose data.
