jonnyGURU
Technical Marketing Manager at Corsair Memory
- Apr 9, 2005
Ok. I received this power supply from Spectre and have taken it apart and taken pictures (to be posted once I resize them. I take them at 2048x1536 so I get good detail) and have made some observations....
Although this power supply is the same as a Mad Dog Sure Power Smart Cable (which model is inconsequential since ALL of them have 30A on the 12V rail. The only difference in output voltage specs is the 5V rail.) it's better in every way....
First, it has one large 140MM fan instead of two or three 60, 70 and 80MM fans is quieter! Furthermore, the fan spins for a couple minutes after shutting down, so the power supply keeps cool.
Sacond, it costs less!!!!
The box says it has Active PFC, but I was reading a PFC of only .70. Not bad, but not great. I could even see the Active PFC mechanism on the AC input inside the PSU, but .70?
The Superflower also uses 1200uF caps on the input side instead of 1000uF like the Mad Dog. Of course, anything over 800uF is overkill, but overkill isn't a bad thing if the alternative is a cap blowing up in your PSU!
The efficiency is really decent at 75%. That's even better than what I was getting with the Mad Dog which was at 68 ~ 73% (depending on load.)
As with most power supplies that have big 12V rails, when you load the 5V on this thing, ALL of the rails go NUTS! So no doubt, don't bother with the 600W Mad Dog if you're thinking "a few more watts are only going to be that much better." You'd only be throwing your money away.
Sure, you can't walk into a B&M and buy a Superflower... but you guys aren't typically B&M guys.
More later.. and thanks Spectre for allowing me to play with this power supply!!!
