Specs to play NFSU Smoothly
tree_
What are the minimal specs to play Need for Speed Underground smooth like around 50-60 fps? I'm wanting to build or upgrade one of my rigs and make it a race car type thing with wheel and pedals to play my racing games on.
i played nfsu great on my old celeron 1300@1600, 1gb ram, geforce fx5600u, 440bx motherboard. what kind of system do you want to run it on
Smoothly at what resolution / detail level?
You could get away with a decent AXP and Geforce 3 for 1024x768 and medium detail.
Personally I'd go for the following, minimum:
XP 2400
Biostar M7NCD Nforce 2 mobo
512MB PC2700
Used 4200
Might be able to get a good used deal on a 5700U or 5900XT
played the demo on max everything (1280X1024 res due to monitor restrictions :eek: ) on the below system \/
I'd just go for "cheap but decent" parts if you're building...
Athlon XP
Basic NF2 mobo
2x256 ram
Whatever HD
9600XT/pro or 5700U
You mentioned something about upgrading an existing rig... what are the specs on it?
I'd load it up on that machine, set the res to 640x480 (or less, if possible), and see how it runs. If it's slow you need ram and/or proc, if not crank it up till it's too slow & decide if you need a vid card. Also, try cranking the detail @ low res, since on a lot of games more detail = more CPU/ram.
For now I was thinking of using my old P4. But it's an older P4, 1.5 gig, 1 gig of pc133 sdram =[, and a geforce2 gts. But I don't think it will play well if at all on this so I was thinking of buying a cheaper AthlonXP/nforce2 mobo set on here and try that. Or would I need a better video card also?
