Jul 25, 2006 #1 V vincer20 Limp Gawd 2FA Joined Sep 5, 2004 Messages 458 I'm looking for some 16awg single strand speaker wire in different colors. Who can send me in the wright direction? thx for you're help
Jul 25, 2006 #3 R rayman2k2 Supreme [H]ardness Joined Aug 6, 2002 Messages 8,069 I don't know about the 'wright' direction, but i can send you in the 'right' one... ...try monoprice, or home depot...
Jul 25, 2006 #5 T tdg 2[H]4U Joined Jan 27, 2003 Messages 3,816 Any wire of the right gauge will work just fine.
Jul 25, 2006 #6 A AMD Man 129 Limp Gawd Joined Jun 21, 2006 Messages 136 tdg said: Any wire of the right gauge will work just fine. Click to expand... yep... just has to be the right gauge wire. basicly any wire of the right gauge
Jul 25, 2006 #7 V vincer20 Limp Gawd 2FA Joined Sep 5, 2004 Messages 458 this should work then wright? http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=156&products_id=2268
Jul 25, 2006 #8 T tdg 2[H]4U Joined Jan 27, 2003 Messages 3,816 That'd work, it's 18 gauge though which is smaller than the 16 you were looking for.
Jul 25, 2006 #9 S scottatwittenberg 2[H]4U Joined Apr 10, 2002 Messages 3,306 i would say to get the cheapest 14 or 12 gague you can find.. oxygen free and all that doesn't really matter. you will never hear the difference.. look through here and see what you find.. http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=56&ObjectGroup_ID=374 or check out local stores
Jul 25, 2006 #10 V vincer20 Limp Gawd 2FA Joined Sep 5, 2004 Messages 458 one last question will 1/8 cable sleeving be tight on 16awg dual wire speaker cable
