Hi everybody,
for the everybody that doesn't know me, Im Henry (in english) and im fourteen, the project which I wanted to risk, as the name says the name, is the realization of an acoustic box inside which I will put the hardware of my pc from scratch .
.. after almost one month of "ideation", I have begun to try to give form and measures to this "case" that will take then the name (thanks to the help of wolf) of SpeakeR Project.
At this point I didn't have to do anything else other than to pass to the real thing .. but before beginning, I have decided to consult some people really kind and cordial and above all with a lot of experience that is: Lupo, Rigor, e _FAX_..........
Talk to you soon with the first updates!!!
Therefore, for first thing I had to make sure about count me some approximate encumbrances of the hw and, appraise the possible positions after some study (really few) here is thing has come out!!!
afterwitch, takings some measures, have marked the compensated by to cut ..
and I have made a further test before beginning to cut
considering that it was all well, I have performed the cut (dont have the photos of the workmanship in how much the photo camera had a bead battery )
Its time to cut the panels and to see the real dimension of this box!!!
Here it is with the hw supported inside ..
and here are the walls of the houses to glue
(you excuse for the photo un focused .)
