Speaker Help
ArrowMk84
I replace my home theater's AV receiver over the weekend, and I'd like to use my old one (Sony STR-DE995) with my computer. Hooking it up to the PC isn't a problem, but should I try to use my Klipsch speakers or should I look at getting new ones? Also, any ideas how can I hook up the Klipsch subwoofer to the receiver?
To connect a sub, just connect it to the subwoofer output on the receiver.
You can connect the receiver to the PC and connect whichever speakers you want into the receiver and you're done.
