So for a few years now I have been using Logitech z906 speakers. They have worked well and have pretty decent audio quality. The set before them I had was the z5500, and I still own them but being military and having to move a few times the movers have really cosmetically ruined the subwoofer and a few of the satellites are pretty scuffed.
I have been looking around at different speaker setups and apparently there aren't really any 5.1 speaker sets made for PC's anymore... Plenty for the home theater but all which require a receiver, and if connecting via optical completely remove the need for a decent sound card since all the audio would be handled via the receiver...
My dilemma... My z906 is damaged and the analog audio suffers from booming feedback because one of the inputs is loose. It works fine via optical/digital but I like to have output from my monitor through analog so that I can play console games via HDMI and have sound from my computer desk.
My z5500s are a little beat up, but they work, and a newer option would be preferred.
I have been looking around and it seems my options are a receiver with 5.1 output to bookshelf/standalone speakers.. or find the almost mythical Klipsch ProMedia Ultra 5.1 speakers used which have gone through the cooling upgrade, because apparently they are the only 5.1 setup to sound any better than the z5500, however they fail indefinitely if they haven't been modified, or revert to a 2.0/2.1 system because the 5.1 options for PC suck.
I could always go for the Audioengine A5+, which are apparently amazing, but 5.1 for gaming is rather nice and I like to have surround audio when listening to music. The Klipsch ProMedia 2.1's are still available, but I hear they aren't nearly comparable to the 5.1's.
So I find myself at a crossroads, I want some nice 5.1 speakers for my pc for gaming, but they really don't make any. Should I splurge on a good sound card and get the analog only 5.1 Pro Media Ultra's or find a cheap receiver like the Yamaha RX-V375 and the Energy 5.1 Take Classic speaker set? It just seems so large to keep around my desk compared to the Pro Media Ultras?
What setups do you all have? What would you recommend? Thanks!
