Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
I overclocked my AMD64 3000+ to 1961mhz by just upping the FSB, however my left speaker now crackles every once and awhile, do you think this has something to do with the overclock or is my speaker just getting old and crappin out?
Well I see a few ways you could address this problem... You could reduce your overclock, even back to stock speeds, and see if the crackling persists. Or, you could try a different set of speakers. Either way you'll figure something out that you don't know now.
Odds are you haven't locked your PCI bus. Your sound card is getting more voltage than it should, which is causing the pops. Try locking it and see what happens.
