Hi guys,
I'm curious to know what kind of wire I should use to extend the current length of the existing cable on an LCD mod I'm doing. I've heard that thick speaker wire works just fine for this purpose, but I'm curious if this is accurate. The load on the wire will be somewhere around 24 VAC and under an amp. Anyone have suggestions, or can someone correct me if I'm hazardously wrong? it would also be helpful if anyone knew the limitations of speaker cable, or exactly the minimum awg I would need.
TIA.
TIA.
