speaker buzz
Discussion in 'Computer Audio' started by silk186, Oct 8, 2018.
  1. silk186
    silk186 [H]ard|Gawd
    1,589
    Feb 26, 2008
    This may be a stupid question... I've noticed that sometimes my speakers buzz when the speaker wire is moved when I move my mouse or keyboard. I'm using the 3.5mm auxiliary stereo cable that connects from the motherboard audio out to the speakers (in sig). I'm wondering if I order a shielded cable would this prevent the buzzing?
  2. B00nie
    B00nie [H]ardness Supreme
    7,812
    Nov 1, 2012
    It's possible. Your cable may be damaged or it's a simple ground loop. Ground loops are extremely common with computers connected to amps or active speakers. You can try installing a galvanic isolator or a ground potential lifter (about 20 bucks) between the computer and the speakers.
  3. silk186
    silk186 [H]ard|Gawd
    1,589
    Feb 26, 2008
    You learn something new every day. If it is going to cost that much I will hold out for a while and make sure my next speakers have an optical input.
  4. pendragon1
    pendragon1 [H]ardForum Junkie
    11,156
    Oct 7, 2000
    you can play around with what power socket the speakers are in to see if that helps too.
  5. B00nie
    7,812
    Nov 1, 2012
    If the buzzing comes only when you move the cable accidentally, most likely the cause is a broken connector at the source or speaker or a broken cable. 3.5mm jack sockets break quite easily if they get twisted.
  6. silk186
    silk186 [H]ard|Gawd
    1,589
    Feb 26, 2008
    I just replaced the motherboard. It seems to be when the speaker wire is on certain other wires which is why I was thinking a 'better' wire might help.
    I'm using the wire that was included with the speakers.
  7. pendragon1
    11,156
    Oct 7, 2000
    It might. You could try a ferrite filter/choke too.
  8. silk186
    silk186 [H]ard|Gawd
    1,589
    Feb 26, 2008
    That's a cheaper option to try. I haven't seen one in a long time.
  9. pendragon1
    11,156
    Oct 7, 2000
    got an old vga cable kicking around? the lumps on the ends of cables is usually a choke. you could rip one out...
  10. B00nie
    7,812
    Nov 1, 2012
    Just be careful not to choke your monkey accidentally.
  11. pendragon1
    11,156
    Oct 7, 2000
    I said rip not rub...
  12. capt_cope
    capt_cope Gawd
    901
    Apr 12, 2009
    The rippin' and the tearin', the rippin' and the tearin'
  13. silk186
    silk186 [H]ard|Gawd
    1,589
    Feb 26, 2008
    I do actually. I will take a look at it tomorrow. I did a bit of reading and it seems they have all different types and made selecting one sounds overly complicated. They are very cheap on ebay for a pack of 4-5.
  14. pendragon1
    11,156
    Oct 7, 2000
    ive used clip on log style ones and the round doughnut style where you loop the cable through and around it. didn't know there was supposed to be a difference.
  15. margrave
    margrave [H]Lite
    118
    Feb 15, 2018
    Miniature phone plugs are a nuisance. They're just not reliable. The cable assembly on the plug is weak and is subject to breakage. And the jack is also unreliable.
    You said you get a buzz when you jiggle the cable. That's a bad cable or a bad jack. (Not a shield problem, and not a ground loop.)
    silk186 likes this.
