I can't find anything about it on this AM3 motherboard I have but there is a connector on the board which seems to be for CD in but it is also labeled HDMI/SPDIF
it is a 4 pin connector. the current board in my media PC has SPDIF coax audio out and it is a 3 pin connector.
so, do they make a 4 pin coax header and how do I determine if it actually has this ability?
this is the board
http://www.newegg.com/Product/Product.aspx?Item=N82E16813153185R
if you look at the third picture and do the hover/zoom thing. just above and between the two PCI slots there is a 4 pin connector and you'll see it says CDIN/HDMI/SPDIF
this is the board
