Sparks, Fire, Smoke!
AliP
Now I have a little story, for a few days my expensive effective 750W Forton PSU has been a little noisy, so I decided to change the fan... Everything looked like it was working perfectly, until I did the final test before reassembling the build, the PSU had been making a little high pitch noise before that test but I thought it was normal. Well I plugged it in, and turned it on... About a second later I see this huge spark and a fireball inside the PSU and finally black smoke coming out the back.. Great! :mad:
After hitting myself 50 times in the face I've decided I need a new one, one that is noise free and can supply more than enough power for a rig below, Pros would be if it is modular and powerful enough and it must be quiet, as you can see above I do not tolorate loud PSU's, While still not going way out of my price range under 250, 300 Totally Tops.
I found this one at frozenCpu:
http://www.frozencpu.com/products/5..._Power_Supply_Unit_-_ST85F.html?tl=g11c26s213
Is it good? Quiet?
Any suggestions would be appreciated, Thanks.
Edit: after examining the PSU the Damage looks like its at the fan "port", The base of the fan wire had gone off for some reason.
This one looks good:
http://www.frozencpu.com/products/5...r_Supply_OCZ850GXSSLI.html?tl=g11c26s86#blank
Suggestions?
How about this one:
http://www.frozencpu.com/products/5...SLI_Ready_CMPSU-620HX.html?tl=g11c26s84#blank
Is it powerful enough to power my system? And if, how much headroom?
Your system is pretty close to mine and I have that Corsair unit so I can certainly tell you that it is plenty powerfull and quite quiet too. (I never hear mine so I assume it's quiet enough) I tried a few power calculators on the web and basically found that I stress this PSU only around 50-60 percent, so there should be plenty of headroom...
Thanks M8, you saved my day.
You can find teh corsair 620 cheaper elsewhere, shop around.
I know but I prefer a site where they accept international credit cards (not in the US Atm), and other payment methods are just not worth the hassle.
