GotNoRice
- Jul 11, 2001
I got a Sparkle 530watt from newegg last week and just got the chance to put it in my fileserver. After the fileserver had been on for about 6 hours, it started making this really loud noise. It sounded like what it sounds like when a wire inside your case gets sucked into one of your case fans. Ended up being that one of the fans on my power supply broke. From the center of the fan, there is a 4 way crack going outwards. This was causing the fan to be off-balanced and rattle.
Well, I guess I could have just RMAd it or something, but I didnt really want to wait. I opened it up, took the old fan out, and went to put a new fan in when I realized that the old fan was smaller than normal, ugh. It was like 20mm thick instead of the normal 25mm or whatever.
Anyway, I ended up just taking it out. In a regular power supply, that only has one fan, I wouldnt have even considered just taking this out, but this is a sealed powersupply (meaning it doesnt have random vent holes everywhere) and has both an intake and an exhaust fan. Even with the exhaust fan removed, there is still airflow through the powersupply (though obviously not as much as there was before).
Do you think Ill be fine just leaving it with only that one fan or what?
Cliff notes:
Exhaust fan in powersupply broke.
Replacement I thought would fit was too thick.
Removed it instead of replacing it.
Wondering if the intake fan alone is enough to cool the powersupply.
EDIT: Here is the link of it with pictures so you can see what I mean about it having an intake fan in addition to the exhaust fan.
http://www.newegg.com/app/ViewProductDesc.asp?description=17-103-489&depa=0
Cliff notes:
