span 3 monitors
utshost
quick question, i need to find something that can span flash, or wmv files across 3 monitors at higher res than 800x600(2400x600) what im testing now is maxtor's triple head 2go and its cutting the last 2/3s of the 3rd monitor off in flash and wmv's. it works fine in 2400x600 but i need to do 3072x768 or even 1024. anyone know of a better solution? I need to be able to span moving adds accross 3 monitors and this triple head thing isn't working. thanks for any help you can give,.
According to Matrox, the TH2G supports 3072x768...
What model TH2G are you using?
On second thought, another option you might want to look into would be adding a PCI video card to run your third display... that may actually be the most cost effective solution for you...
yea thats what i was starting to think, just get two video cards because i know that works. thanks.
the analog th2g unit runs at the same res as the digital.... So that isnt the problem.... Native resolution is 1280/1024=5/4 screen.... so wondering if the resolition your using is a differnt format... and maybe there just isnt data being sent to the screens... Or maybe your gpu isnt robust enough to send that much data... Or maybe the projuct your running cant suppoer that wide of a reslution...Go here and look around http://widescreengamingforum.com/forum/viewforum.php?f=57&sid=1b1d602d539aeaa23423038874f1b5eb
that is the wide screen gaming fourm... they should be able to help you there...Also contact matrox-- they seem like a good company and customer service shoudl help ya out... goodluck
