I have wondered for a while if the weight of a 5th leg outweighs(literally) the stability advantages. With 5, any one can fail and it would still be somewhat stable.
Once that first stage has burned all the fuel, it's *very* tail-heavy. You've got nine engines, plus all the turbopumps and other equipment, sitting down there. It's actually quite stable. Once it's on the ground/platform, it's gonna stay put. Keep in mind that when it launches, it's sitting on a far narrower base, albeit on land.I'm curious though, with rough seas and an object THAT long with those short legs, it seems like even if they landed it with no problem, the thing would still potentially tip over during transport. Why not create some sort of capture system that would stabilize the rocket from the mid/top section? They don't have a problem with precision locating the rocket, they just have a problem at this point with it staying upright once they're near the ground.
seems a bit doomed to failure unless the sea is as calm as a mill pond
