Zabuzaxsta
- Jan 19, 2012
Does anyone know a good 120mm rad (I'm flexible as far as thickness goes) for cooling an i7 2600k CPU on its own? This is my first build, so I selected a Phantom 410 case, and am now finding that it really doesn't have enough internal space for watercooling a CPU and a crossfire/sli setup. I can't get rid of it either, since my wife bought it for me for Christmas. The only way I can make it work is to save the 240mm space up top for the GPUs (it can house a dual thickness radiator, supposedly) and then use a thick 120mm for the GPU on the base of the case next to the power supply.
I'm gonna want to overclock the i7 pretty significantly (not something crazy, but definitely the 4.5-5.0 Ghz range if possible), and I want to know if there is a good 120mm rad people suggest for this. I've looked into XSPC's RX120, and it seems like it would work well. Does that seem sufficient to you guys? There's gonna be two loops, so that would mean two pumps (prolly MCP655's) and XSPC's dual 5.25" split bay reservoir reservoir. Price is really no object here, so however I can make this set up work I'll make happen - just tell me what you think and what thoughts/suggestions/ideas you have.
