space between case/mobo in shuttle
bleed3r
Yeah, so the ICE holes are the same as p4 hs mounting holes in an SNG45.
Are the mounting screws removable that go from the bottom of the case to the mobo that the ICE hs screws into?
How much space is there between the bottom of the case and the mobo? This is to know if the X-plate will fit for an SLK947U.
I'd really like to have an SLK947U over an SLK900A :(
If the plate doesnt fit, what does anyone think about cutting a hole the shape of the X-plate so it extrudes thus fitting? Would this be dangerous to the cpu or anything with it exposed?
