Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Thanks for the info.
Which fan would be good if i don't mind the noise?
My friend has 92mm delta now, dont know the model.
feels like a stand fan set to medium, sounds like a ferrari driving by, is that one good?
92mm vantec tornado is what a lot people use, you might see if you could find a delta that pushs more CFM, but the tornado's CFM is massive...
Personally, the noise would make me go out of my mind. If you want a quieter solution, 92 mm panaflo fans are nice. Of course, it's like half the CFM...
okay.
would it be better to blow air onto the hs, or invert the fan so that it sucks air out instead?
i have a 120mm exhaust fan at the side of my case right ontop of the hsf
