SP35P2 PRO - RAM
Nhont.
I am still new to the SFF and need a bit of help.. after reading about SP35P2 PRO from shuttle.com i was wondering to what RAM can this shuttle use so i was curious to whether can this type of RAM work: Corsair XMS2 PC2-6400C5DHX and i notice that the XMS2 PC2-6400C4DHX works fine but i wanted to know has anyone have the PC2-6400C5DHX installed in their SP35P2 PRO?
Any help or thoughts would be helpful thanks again,
NhonT.
I have the CL4 version of that set and it does work, but it's a tight fit as there is only about 1/4" of clearance between the top of the heatsinks and the PSU. What you do is tilt it towards you when getting it over the slot, then tilt the left end into the slot, followed by the right end. Do the reverse to take it back out. Great RAM and worth the minor difficulty in putting it in.
It should fit and it will be a tight fit as Blahman stated. I have some Dominators(PC8500) and they fit with about an eighth of an inch to spare. Corsair is the the only way to fly!
