After a couple weeks of research I decided to build my first shuttle, as a hardcore gamer I decided to go with Shuttle's XPC PRIMA SP35P2 PRO. Here is a list of parts I used to complete the barebone:
e6750
eVGA 8800gt superclocked
2x2GB G.Skill PK's w/ OCZ Memory Cooler
vista x64
BenQ FP94VW Silver-Black 19" 2ms
Asus 20X DRW-2014L1T
I DID NOT reverse the fans as many have advised. I don't trust the 2 little outtake fans on the back of case to push all the hot air out by themselves, and didint like the idea of cpu heat being expelled inside the case. I put a generous amount of arctic silver 5 on the cpu (a straight vertical line down the middle) as explained in dual core AS5 application instructions. Popped in the video card, memory, and installed the OCZ memory cooler with an unnoticeable ghetto mod that I'll eleborate on in just a bit. The optical drive was installed without any adjustment to the push level and it opens smoothly. The machine booted up with no problems and I hit delete to get into the BIOS. After loading the optimized settings in the BIOS I installed vista x64 with no problems what so ever. Without installing any drivers I was able to connect to the internet and fully update vista, that took a little while. After my OS was fully updated I restarted the computer and installed ONLY drivers for video card, LAN, and audio. However, before installing video drivers I flashed the eVGA video card with a BIOS which fixes dynamic fan control, this fix can be found on their site. I will not attempt to install the chipset drivers until I find out it's safe to. There is a bug where after installing the chipset drivers usb ports don't function and this requires a full windows reinstall. I don't know if vista x64 is affected and I won't take a chance to find out. There is a fix for this on the shuttles website for XP only. Also I will not flash to a new bios since winflash is not supported in vista x64. When I need to, I will do it through DOS (USB bootable stick).
here are some pics...
The shuttle's size is perfect for carrying to lans. I still need to get a carrying case for it. The ocz memory cooler also blows air over the northbridge if mounted in a certain way, it will only mount on one side of the memory levers as the 90mm outtake fan doesnt leave enough room for another plate on the opposite side. I wedged a gskill sticker in between the other end and the fan and it nice and snug.
The LED's on the memory cooler give a nice warm touch to the inside of the case and are visible through the case grates. The video card takes up about 80% of the case's length.
Soon I felt an itch to try my first overclock. I raised the cpu frequency from 333 to 400 and left the multiplier at 8. I set the memory multipier to 667 which with my processer gives me a 1:1 cpu:memory ratio. I only changed the DDR2 voltage to 2.1 as specified, leaving all other voltages on auto. I disabled C1E and virtualization. Fans were set to smart mode but I set the system fans to medium and the cpu fans to low instead, this gave me an acceptable level of noise and decent airflow. In vista Control Panel > Power Options, I selected "High-Performance" so the cpu wouldn't underclock using a lower muliplier as in the "Balanced" option. My computer has been on most of the day so I will now take a screenshot of idle temps of this overclock and post it here...
The temps are pretty good considering this is a shuttle, I would however like the northbridge temp to be lower than what it is (47*C), that's with the OCZ memory cooler installed. I will have to contemplate and come up with an idea to get the NB a little cooler. The overclock increased the NB temp by about 4-5 degrees, and the cpu about 6-9 degrees. I'm not concerned with cpu temps as it seems to be idling at a comfortable temperature (40*C) even on high-performance power mode. The video card is also at an exceptional temperature of 55*C.
I'm very happy with my first shuttle build. If anyone has any questions or input regarding the SP35P2 PRO, please post here. I will keep you updated. Load temps will be taken soon. Time to go play some more with my new toy.
EDIT: after some searching I found out that the "motherboard" temperature in everest is not the northbridge, it's actually "aux" that reports the correct NB temp. Aux reports 43*C, I can live with that!
e6750
vista x64
