Soyo Drag0n
Rhino
they say the O in dragon is for overclock, but i dont get it, I have a soyo kt400 dragon ultra (black edition) and i have an athlon 2100. Im trying to get it at 200 front side bus, i know the chip will go there, also my geil ram will run at 200, is there any way to get my board to run at this, what volts should i up, anything??? please help
I had that motherboard and cpu. just go nforce2 if you want to overclock. I had to up the voltage to 2v just to get 2Ghz. Its just not worth it. too easy to ruin your hardware. You can overclock it, but it is easy to loose your cpu. I burnt mine out doing 2.1Ghz at 2volts. Just dont do it.
