Source needed for crimp on SATA data connectors
ns15973
I'm looking to make some custom length SATA cables and I need a source for either,
the raw connector housing, or a cable known to have crimp on/press fit ends.
Thanks for the help.
The digikey one looks close but I'm looking for the one seen in the 4th picture here:http://forums.overclockers.com.au/showthread.php?t=347601
Of all the cables in my collection, most are solder pins, a few are standard crimp with metal tabs wrapped around the wires, and one cable was like the above with the notched V press fit connectors like ribbon cables use.
Almost the same as seen in US Patent 6790075 ... but that doesn't help me buy them.
