I know this has been asked before, and I would have searched, but.............
Need a source and part numbers for 4 pin Molex disk drive connectors and crimp pins. Female and male versions, if you have all that information on hand.
BTW, for future reference for anyone who might read this thread, www.mouser.com was the only place that I could find that stocked all 4 of the above parts.
Just got my order in today from Mouser. The pins are correct, but the connector housings are not correct. Those part numbers correspond to a 4 pin housing that has the corners rounded, instead of having the bottom corners square, and the top corners 45'ed. These connectors can still work, however, if you take a grinding wheel to them to shape them real quick. Just a heads up for future searchers........
They have all colors and UV reactive ones too. Even motherboard power connectors, 5-pin aux connectors, and 4-pin P4 connectors as well as 3-pin fan connectors and the standard male/female 4-pin molex connectors.
