soundstorm and mic?
Dome
i'm running my sound off of my abit NF7-S onboard sound and i haven't been able to get my mic working. i was wondering if you guys know of any sort of driver issue with soundstorm and microphones.
my nf7-s onboard sound is finicky with drivers. About 1 out of 3 work correctly....meaning at least 3 newish driver sets should be tried imho. If you've gone that route already then go over the audio control panel with a fine toothed comb and test changes along the way.
It may sound idiotic but are you certain the mic works correctly?
List everything you've tried so we know not to give redundant advice on the next round :)
For more research try:
http://forum.abit-usa.com/forumdisplay.php?forumid=26 <- official abit forums
http://www.nforcershq.com/forum/index.php <-- tons and tons of info
http://forums.pcper.com/forumdisplay.php?f=7 <-- decent resource
http://www.motherboardfaqs.com/content.php?content.57 <-- not sure how good
hope you clear it up quickly
i'm pretty sure its the drivers because i'm pretty sure i've run through the full gamut of microphone options. i've checked that my speakers (klipch 5.1 ultras which use 3 plugs into the sound card) aren't plugged into the speaker port, and it doesn't look like they are. and then i've been through and tried to check all the different settings.
i'll start looking for drivers, are there any you guys could recommend? i'm not sure which ones to download, as there seem to be a ton of like unified drivers and other such nonsense
