Soundstage
Comixbooks
What the heck is Soundstage I hear all about it....but clueless to what it is?
Soundstage is about the space between the instruments in order to create a realistic 3 dimensional image. A "good" soundstage usually involves extended, controlled, uniform dispersion from a loudspeaker. The best ways to achieve this is usually through either a coaxial driver like you see with KEF or TAD, or with a large waveguide on the tweeter to match the directivity of the woofer in the crossover region like you see with Amphion or Revel.
Great explanation but I've heard soundstage from all sorts of stuff even cheaper setups. Sure the bigger rigs with more space, bigger room and better response/clarity win here by a big margin, but most speakers/amps can do it, with a big but attached.
The real trick is setup of the speakers. Hell even these cheap logitechs infront of me currently (torture after my home rig) with only 60cm spacing have a moderate soundstage. This trick is to have an isosceles triangle or equilateral triangle to the listening point.
At home my workstation/desk is directly behind the centre of the couch, so I aim/setup my speakers to target this point. On the couch the spacing is wider (so the soundstage is a little more useful for 2-3 people) and at my desk it's perfectly aligned to each side of my head/ears. It sounds like certain instruments or effects are taller than the roof and arranged very nicely around the room as they would be in a band.
A small ~2.5" full-range driver definitely would produce excellent imaging, it just has other problems which the 2-way or 3-way system tries to solve for (primarily non-linear distortion, but also lack of extended frequency response).
