My computer has always made a clicking sound when I click on a link. For some reason this just stopped, but I can't figure out how to turn it back on (or atleast check to see if it's on to see it there's another problem).
Are you looking in the right place? If using windows XP, goto control panel, then open sounds and audio devices properties.
Click the sounds tab
Scroll down to the Windows explorer, and there should be something called "start navigation". This is the sound you are refering too.
There should be a little speaker icon next to it.
if its not there, highlight it, then click the browse button and browse to the "Windows XP Start.wav" Audio file. (you can do a scan for it, and if the scan does not turn up a audio file, it got deleted somehow.
