Soundcard options for A=>D input conversion
Hey'all,
I just installed an older tv tuner card (analog cabe input) in my HT system with the audio out going to the aux in on my Chaintech AV-710 sound card. This is hooked to an Onkyo receiver via the SPDIF optical out. The problem is, the card does not do A=>D conversion on the A inputs, so the signal on the aux input does not come out the SPDIF. Older drivers for the card have a recording loopback A=>D option, which puts the A input to the D output, but this introduces an annoying noise into the system. More recent drivers have eliminated this option. I have to run a separate analog cable to another input on the receiver. So, the question is: what sound cards are available that convert the A input to D output and has an internal aux or CD input?
Thanks, I checked it out and the pci version appears to do it based on the second spec line below, but it's not explicitly stated anywhere.
Analog Line Inputs (2)
Type: DC-coupled, low-noise input circuitry
A/D converter: PCM1804 <===================================
OpAmp: NJM2068
Level: -10dBV nominal, 6dBV max (unbalanced)
Frequency Response (20Hz - 20kHz): +0.20/-0.10dB
Dynamic Range (1kHz, A-weighted): 111dB
Signal-to-Noise Ratio (A-weighted): 111dB
THD+N (1kHz at -1dBFS): -100dB (.001%)
Stereo Crosstalk (1kHz at -1dBFS): < -120dB
