Jellyfishpudding
- Oct 12, 2006
Thanks to an electrical storm whose lightning found our deck attractive, the front panel audio on my Xonar card delivers sound with horrible static. The speaker output was unaffected.
And so my limited knowledge tells me to just disconnect the HD Audio cable from the Xonar and connect it to the slot on my motherboard. Would this work? If it would, I question whether or not the audio would auto-switch from speakers to headphones when they are plugged in.
I'm fine with getting a new card. Just wondering if there's a workaround. Thanks in advance for your help!
