Soundcard and IRQ HELL
I thought fighting an ISA soundcard and the IRQ setting was a thing of the past with XP and ACPI managing IRQ's.
Got a new Creative XiFi gamer PCI sound card. I have a micro ATX motherboard, from an old SFF build so PCI slot 1 is covered by Video card cooler, and that leaves me PCI slot 2.
Put in sound card and drivers won't load. I keep being prompted for the location of files even though they're right there on the cdrom. Computer then keeps rebooting after detecting the new sound card. Hardware conflict. Called Creative support and he tells me to just put it into another PCI slot. I explain I only have 1 other and it's blocked.
So I use onboard GPU video, remove video card and use PCI slot 1. Works like a champ. Install all drivers. Now I try to dupe my system, and just move soundcard to PCI slot 2. Works for 1 boot, then back to the constant hardware conflict reboots. (I read PCI1 and PCI 2 share an IRQ. Not sure why it works in 1 but not in 2) I previously installed an SBLive card in PCI 2 and it worked fine.
Check BIOS. I cannot remap IRQ's. Only reserve certain IRQ's for ISA legacy. I try turning off PnP OS, and ACPI, and reserve a couple IRQ's. Doesn't help.
I read I can re-install my WinXP to not be ACPI, but instead standard PC in which I might regain some control of my IRQ's again. I'd like to keep ACPI for my cool'n quiet for AMD.
How can sound cards still be so stubborn about IRQ assignments?
Has anyone else had this issue?
Is there another fix other than reinstalling OS?
IRQ's in the 5-9 range prefered by sound cards
5 I have nvidia nforce PCI mgmthave
6 floppy controller despite it being disabled
7 empty
8 system CMOS clock
9 AMD ACPI
I'm hoping someone has an easy fix for this before I go back to onboard AC97 sound.
I do also have a PCI-E 1x connector below PCI 2, but can't seem to find any sound cards that are PCI-E 1x
-ND
What main board do you have. Some boards have a setting in the BIOS to force the main board to assign IRQ's. Which may help in your case.
Asus A8N-VM CSM bios 1001
The only option I saw was to change select IRQ's to reserved, which the detail says is for legacy ISA.
Tried Creative tech support again. Was hoping they could help me change the IRQ, but was told their card will not work in all systems. Despite my SBLive and other cards working in that same PCI slot.
They told me to go ask my motherboard manufacturer for a BIOS to change my IRQ's per PCI slot. Yah, that's gonna happen.
Now I remember why I liked onboard audio so much.
If you bios has it try the option "Reset ESCD data" or "Reset Configuration Data " select that in your bios and reboot.
if not try resetting the bios.
What happens if you remove the video card but still use pci slot 2?
Maybe in addition remove the floppy drive as well.
And you might as well (if you haven't done so already) disable both serial ports in your bios and the parallel one as well unless you need it. That'll free up some IRQ's.
Maybe if that works you could then put the vid card back in with no troubles. Worth a try...
