Sound Troubleshooting: Gateway MX6441 Multiple drivers fail
Punkrulz
Hey guys,
You know, when it comes to reformatting computers, I really can't win when it comes to sound drivers! My friend has given me his Gateway Laptop, an MX6441 for me to repair for him. I reformatted it with Windows, as he did not have the disk that was provided with it. I hopped onto Gateway's website to obtain the drivers, which say they're a Conexant driver. The device on the laptop, using multiple hardware scanners says it's an ISB400 by ATI... however I can't find any such drivers. I have been reading around and I'm hearing that this device and the modem are the same... but again, Gateway's drivers don't match up.
I used Gateways, but the installation states that the device has failed. Since it's an AC'97 codec, I attempted to use one from Realtek... however while that one does install, in the control panel it says that the device cannot start. Is there anything else that I can try to use, since the manufacturers website can't even give me the correct driver?
This is for Windows XP btw.
Thanks!
I was already in that thread as one of my first things looking for that driver. I attempted to use the driver that was listed, but it didn't work. I'm wondering if I'm doing the "forceful" install correctly. I googled around for how to do the Forceful install, but wasn't able to come up with anything. What do you have to do, step by step, to do a forceful install???
Thanks!
Thanks!
This guide sums it up:
http://members.shaw.ca/jaws75/
When you used the Gateway drivers what do you mean by it failed? Did it install and then failed to initialize on restart?
No Heero, when I said it failed, the Conexant drivers that Gateway provided utilize a setup.exe file to install. You double click, it confirms the device you're about to install. Goes through a setup that states it's copying files and what not, and then it gives you a status of the installation for the device you were just attempting to install, which in this case, says failed. If you tried to utilize the driver directly, I would get error messages about there being no hardware present for that to work.
I did wind up getting the driver to work.
1) I previously had attempted to install Realtek AC'97 Audio Drivers. This would at least cause the device to show up in my System Manager, however it would state that the device could not start.
2) I would go and try to update the driver. I would select all of the manual options, I'll find a driver, etc. When it came time to select the driver, I unchecked the box that said "Compatible Hardware". On the left hand side, an option for Conexant appeared. I selected that (rather than select the driver manually). The driver installed successfully and the audio device worked afterwards.
Pain in the arse to get working if you ask me. :( I'll review the guide you posted, maybe there are some things in there that I wasn't made aware of before.
Thanks!
