Sound Problem, Please Help!!
HardD99
ok i curently am using my onboard sound from my IC7-G ABIT mobo. it has worked great for past 8 months or so, well lately it is starting to mess up, it works fine for about an hour and then will just stop putting out sound when i am playing a game or listening to winamp. the other night i was playing call of duty and it cut out so i exited game and then instantly loaded it up again and then the sound worked fine again. it does this is all games so its not just that one. anyone ever have this kinda problem? i would hate to spend $200 just to get a new soundcard, i like this Digital Optical out to my Klipsch GMX... please help me
Sometimes onboard solutions (if that's whhat your using) will use software to regulate codecs, perpaps you installed another game that has a codec that's no mixing well (trying to be the default codec in COD). Go to Ctrl/Panel/Sound and Vid Game Controllers - then right click audio codecs and see how many, and what codecs you have in there in properties. Consider lowering hardware accell also, or simply reinstalling your sound driver might fix it.
One of the first things I would try is a different cable out to your speakers if possible. It may not solve the problem, but it is an often overlooked solution to audio problems and it certainly won't cost $200 to try.
EDIT: or try an analog connection and see if you have the same problem
True - there are many things to try. If it worked ok for a long time then it shouldn't be too hard to nail down. Probably a conflict or bad wire/speaker connection.
yeah i tried connecting via digital optical and analog.
the codecs i have installed are:
IMA ADPCM Audio CODEC
Microsoft ADPCM Audio CODEC
Microsoft CCITT G.711 Audio CODEC
Microsoft GSM 6.10 Audio CODEC
DSP Group TrueSpeech(TM) Audio CODEC
msg723.acm
Windows Media Audio Codec
Sipro Lab Telecom Audio Codec
Indeo audio software
Fraunhofer IIS MPEG Layer-3 Codec
Microsoft PCM Converter
