Hi Guys, I know next to nothing about PC audio or Audio in general. I am a gamer. I could really use some help with the following sound issue on my new rig.
I am getting low volume out of my new set up. I have to crank the volume up on everything(headset/card/windows) setting to get remotely loud sound out of my headset. I also notice that my MP3s seem to lightly fade in and out on volume while I play them. In general, it sounds like shit compaired to my last audio setup(Logitec G35 USB headset). I would have just got that headset again but it was too heavy for the amount of hours I game(I'm retired).
My best guess is that the card is not enough to power these headphones correctly.
Rig and settings:
Windows 7 64bit
Corsiar HS1A Headset
Asus P8Z68 Deluxe (Bios 0603)
i7 2600k @ 4.7
EVGA GTX 460
8 gigs Corsair @ 1600
realtek ALC889 8-Channel HD Audio codec(Disabled in bios and drivers not installed)
Asus Xonar DG
Audio Driver Version 7.12.8.1794
GX 1.0.10.917
DSP info 1.1.3
Xonar Settings:
Audio Channel - 6 Channels(2 sounds horrible)
DSP Mode - Dolby Headphone DH2 (Gives most Volume/sounds best)
Sample Rate - PCM 44.1 KHz
Analog Out - Headphone Pro gaming Mode or for 32~64ohms Headsets
Hi-Fi - Off
GX - Off
EQ - Set to soft rock(seems to sound best. Way better than generic)
Every thing else on default.
In control panel I set output to match at 16bit 44.1Khz or 44100 Hz
The Asus Xonar is only active sound output device.
Volume in 100% on everything everywhere.
I'm just not happy with my sound. It's kinda low, unpowerful and generally crappy. It does sound better than the onboard sound(realtek ALC889 8-Channel HD Audio) it just still sounds bad IMO.
Thank you for any and all suggestions.
P.S. I do use vent when I game if that matters. The Mic seems to work fine.
Edit: I'm using the Corsair HS1A Headset....oh brother lol
Rig and settings:
Windows 7 64bit
i7 2600k @ 4.7
EVGA GTX 460
Asus Xonar DG
GX 1.0.10.917
DSP info 1.1.3
Xonar Settings:
Hi-Fi - Off
GX - Off
