Sound dampening material
Slartibartfast
Anybody ever use this stuff? It seems like a good idea in theory, but from what I've read it doesn't seem to make much of a difference.
I'd also like to know, I'm interested in purchasing some of this stuff.
i used Dynamat to cover the inside of a case. it helped but was exspensive. note pull all your hardware before attempting install. one way or the other your pulling it out, so do your self a favor and do it before you start dynamatting.
Words of caution the skin of dynomat is conductive and if you do this you need to make sure you have great air flow as it will trap alot of heat if your not careful.
http://www.dynamat.com/
