Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Do these even exist? I want to have internal speakers (with magnetic sheilding, of course ) in one of my mods, but i don't want an ugly wire coming out.
well you could use the snd card's front panel connectors ( for example to connect a sb adugiy to the speaker and mic connections on the front of a case )and make your own connector, or tear out the connector on an old case
I'm assuming you mean internal output, not input, right? A lot of soundcards have both these days. If you want internal output then make sure the card has a front panel connector header.
