Sound card uping ping?
Status
Not open for further replies.
UberPooner
Hi, my friend just installed a sound card in his system. he said that his sound card is getting him 50% petter ping. what do you guys think? i don't think the card has anything to do with it but idk. he has this mobo btw http://www.newegg.com/Product/Product.asp?Item=N82E16813128015
Mod Edit: Please don't post the same topic across multiple forums. Your duplicate thread was moved to the appropriate forum Computer Audio here:
Thanks ~ Papa-Ming
http://www.hardforum.com/showthread.php?t=1140600
It sounds unlikely, but if the sound card has specialised processors that take load from the CPU, it is possible it might be improving his network performance a little bit.
But I really doubt any sound card would give you a 50% ping improvement.
Status
