Sound Card Upgrade
PolarLAB
I've been using an Audigy 2 ZS for a couple years now and am now thinking about upgrading? I just bought some Senn HD555's and want to know if a new sound card will help the quality of sound?
A search for "better then Audigy 2ZS" on these forums will give you the answer:
http://www.hardforum.com/showthread.php?t=1216199
Since recently there is Auzentech X-Fi Prelude sound card that adds better quality components to the X-Fi chip. Whether it is worth to get this or original X-Fi depends on speakers that you use (will they be able to reproduce this gain in audio quality from the source or are they average $150 multimedia set?)
