sound card questions
mystic demon
I was looking at audigy 2 zs sound cards on ebay and im seeing platinum edition, gamer, and 7.1 is there a site that tells what the main differences are in these different versions? On another note i was wondering what everyones opinion is on buying a used sound card should i be concerned about it or would you just recommend i buy new? Thanks for all of your input.
