Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Well you're unfortunately out of luck, Zen. The good news is you're in the same boat as I and many others . Right now Creative doesn't have their own drivers, has not open-sourced their drivers, nor given ALSA what they need to make ones themselves.
A simple solution--though not ideal--would be to get a second sound card if you have room. You can disable it in windows so X-Fi will be your card for that OS. Then you can let Linux use your secondary card and every OS will be happy. I have a Turtle Beach Santa Cruz that fits the bill, but there are plenty of options. ALSA has a nice list (thought not entirely up to date from what I can tell) of supported cards here: http://www.alsa-project.org/alsa-doc/
