SolidSnakeUS
- May 29, 2008
Over the past couple of nights my speakers would just flat out stop working (no sound, but power is still on). I try the speakers via my PS3 and they work fine and so do my headphones via front 3.5mm jack on my case (hooked into my HT Omega Striker). Now something new happened, I did get sound out of the speakers (first time I tried to fix it, it got fixed, not the 2nd time), which was really quiet and distorted music that I was trying to play through it. Does that mean the card is starting to go? I was thinking of an Asus D1/DX to replace it, are they good choices? Or do you think my motherboard's on board is good enough for Logitech X-540s (5.1) and AudioTechnica ATH-AD700 headphones? Should I shell out the $85 on Newegg for a new card? Currently, the only thing that works are my headphones, which is what I'm using right now.
EDIT: Or should I go lower with like the Xonar DS instead considering I don't have really high quality stuff?
EDIT 2: Or what is best under $100?
EDIT 3: Should I just get a new one of the same card? This one lasted about 2 years and I wouldn't have to fuck with drivers.
