- Aug 17, 2005
Can someone explain this part of the control panel......the old control panels had a choice of pass thru to spdif or decode in the pc...i cant be the only person this control panel makes no sense.
[/IMG]
if i select anything other than no encoder while watching a converted blueray it doesn't sound as good. I guess no encoder actually means it decodes the audio like in a movie in the drivers instead of sending it over optical or whatever. Am i understanding it correctly?
