Sep 13, 2005 #1 S Steeeeve 2[H]4U Joined Jul 26, 2005 Messages 2,596 I was wondering where you connect the front audio ports if you have a Sound Blaster Audigy 2 ZS. Can you just connect it to the mobo and have it work?
Sep 13, 2005 #2 S Skin Limp Gawd Joined Apr 21, 2005 Messages 471 I think there are pinouts on most audigy cards.... if you plug it into the mobo, im pretty sure that would go straight to onboard.
Sep 13, 2005 #3 S Steeeeve 2[H]4U Joined Jul 26, 2005 Messages 2,596 yeah, it didn't work on the mobo, but the card only has a 1394 pin set and some other random ones.
Sep 13, 2005 #5 S Steeeeve 2[H]4U Joined Jul 26, 2005 Messages 2,596 thats just lame...stupid sound blaster
