Sound Blaster Audigy 2 ZS problem.
DeepFreeze
Last night, I played MOH:AA, no problems.
This morning, I come to my computer and when I try to play anything with sound, the audio seems like someone is hitting mute, unmute, mute, unmute the entire time.
video is fine.
I tried to uninstall old drivers, reinstall current drivers with no success.
has anyone else had this happen?
Anyone seen this? Ive been checking the web, nothing concrete to this problem yet.
sounds like a codec problem. Try installing or reinstalling a codec pack.
Other than that, driver-wise you've covered it. I'd put the card in another pc and see if you still get the same problems.
Tried another SB16 PCI card. drivers wouldnt load when i checked.
ill see if I can try another machine.
Ive reinstalled 3 different drivers.
tried another pci slot. no go.
