Sound blaster audigy 16 drivers
UberPooner
Hay anyone no wehre i can get a sound blaster audigy 16 driver? logitechs website doesnt even have any.
Need some specs here :p
Is it ISA or PCI?
What OS are you going to be useing?
What motherboard?
I have an Audigy 2 ZS, is there such a thing as an Audigy 16? I have heard of Sound Blaster 16 tho....But Logitech doesn't make either of those, they are Creative products. You should go to their website at www.creative.com and see if you find whichever one you have there.
ahhhh sorry its a sound blaster 16 it goes into a pci express slot and i have windows xp.
The SB16 PCI drivers are only basic drivers only, and may not even be included in XP, there is no update.
You can get a much better sound card for very cheap, probably for less than the cost of Gas to drive to a computer store (well, at $4/gal of gas that is :D )
