advanced101101
- Jun 14, 2004
What have yall used for sound absortion? I know dynamat is what i used in my car, but i want something for my pc. I didnt wanna post in the other thread, seemed a tad off topic
advanced101101 said:Hows about the spray stuff?, i can get that for cheap
well I used something along with it... and no - they are not stinky, nor ugly or dusty (I have no windows and NO intake or even exhaust fans (except for the PSU) and the case is pretty much sealed so there's no dust coming in...Moses said:Egg crates? No way dude...
First of all, they not only absorb little or no sound at all, they're also ugly, dusty and stinky too...
Their only purpose when used is to prevent sound waves from bouncing back from the wall...no doubt its cheap...but in no way is it a solution to your PC silencing projects...
I'd suggest first of all KEEP YOUR CASE COVER ON. I guess that's the first and foremost way of beating the noise...another way is not to make so many holes, ie. blowholes in your case. Sounds escapes from any little gap it passes thru...Also you can try lowering the speeds of your case fans but messing around with the voltage pots...only if your PSU and mobo supports it...
