SOS with a HD situation
Catsonar
Ok, so I have a drive that right now hold all my info and OS as well, now i don't have a PC as of now to get the stuff that I need off the HD so I wasn't quite sure as to what to do in order to this. Should i configure the drives jumper pins and make it a slave and connect it to a PC that is running and get the data I need that way or should I do otherwise? Plz help cause this is the only thing that is stoping me from enjoying my new computer.Thx :)
Yes, just connect it as a slave to a PC, backup your data off it (id guess to CDs or DVDs) but if you dont have a PC why is it holding you back from your new computer??
