Sorry, Please delete multiple Posts.
Gaate
Ok, here is the story. I bought a Sabertooth 990fx from newegg, open box. BAD IDEA. I put everything together and then had a problem with my CPU overheating. But here is the thing, i need to RMA the motherboard. But newegg wont RMA it and i dont want to get a refund.
So I was going to go with the ASUS Premium service, where they send my a new motherboard and then i send them mine. The only problem is that i know asus is prudent with their RMA's and there seemed to be some residue on the back side of the Motherboard. Possibly indicating a spill of the previous owner.
I dont want to get the new motherboard, send this one back and then have them charge 150 dollars on my credit card because they desided that the problem wasnt covered by warrenty, so i cleaned the motherboard very thouroughly using Alchohol and a toothbrush, and a little soap and water, but still used with a toothbrush. I just wanted to get the stuff off of it so they couldnt tell. At this point there is NO residue left, looks brand new.
But, is there anything else that could make them think it was water damage? The only residue on the board was on the bottom of it. There does not seem to be any on the top with the capacitors.
