Your probalby talking about an Athlon 64 system, be it a 939 or 754 socket, they both use standard non-ecc un-buffered DDR-ram. To put it simply, they just use standard DDR ram which is used on 32-bit systems.
If it's a socket 940 which are used by some Athlon FX's and opterons, (don't read further if it isnt) then it'll probably used registered DDR ram which gives better data protection during transfer but is alot more expensive.
