Sorry if my brain is not functioning properly got a question.
stealth21
Ok here is my situation.
- sharp 42" aquos (i have atm)
i have a 5.1 logitech speaker system for pc just sitting here a friend gave to me a while ago i wanted to use it. Here is my dilemma...I have a few things i wanted to connect to my tv but i wanted them all to share the same sound speakers no matter which input i select for my tv. Right now i have them all playing back thru the speakers built into the tv and the sound just isnt what i want.
- HTPC (for HD-Dvd and Bluray playback)
- XBOX 360
- Digital Cable Box
All these devices are connected into different inputs into the tv. Now my question is how do i connect the logitech speakers to the tv and allow all these devices to share the same speakers. I am soooo sorry if this is a dumb question. I just think it would make life alot easier for me. Heh yeh so in essence i want all the devices to universally use the logitech speakers. I am not sure if this even makes any sense. Thanks hardforum for any replies or alternative solutions to my dilemmas.
there is no question that is wrong to ask lol, well simple solution is a av receiver for a decent one you can pick it up of eBay for about 250 brand new, but before we decide which one you want, what is your budget like.
sorry if i get a reciever this means i wont be using the Logitech 5.1 speakers? Or i will? haha the whole point is i wanted to not spend so much as these are brand new and i was kinda wondering if it were possible with the current setup to achieve using these. If at most i must get a reciever then i guess no choice lol. Any decent recievers for under 200?
You best bet is to get some sort of audio selector switch to hook it all up to your speakers.
What kind of inputs does that set have? digital coax, digital optical, 6 channel direct analog, etc etc...
Depending on the TV, you might be able to just hook the speakers up directly to the TV, so that the sound goes from the equipment, to the TV, and out the speakers. The tricky part would be configuring it so it all worked well, but it's doable (that's how we have our TV hooked up to the built-in wall speakers). Quality probably wouldn't be quite as good as through a receiver, but the price is good.
Does the TV not have an audio output you could just run to the logitech system? If it's two channel analog I realize it won't be 5.1, but it might sound better than the TV speakers with no extra investment.
